Old 06-14-2007, 04:19 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
You probably have live wire to the guage and then directly to ground.Remember that the current must go from the battery to the ignition switch-to the guage-to the sender- then to ground.Also remember the sender grounds itself when attached to the block with the exception of the fuel sender which will have to be grounded.
Good luck.If you like I could send you a basic schematic.
Good luck
