Old 06-22-2007, 10:58 AM
Tony Radford's Avatar
Tony Radford Tony Radford is offline
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
I have put a plan in motion. I ordered the BFGs, which should arrive at NTB on Monday. Someone will ferry the tires to J3 Motorsports where they will be mounted, ballanced and put on the car. They will also set up the suspension, making any suspension adjustments that might be required due to the tires being slightly larger (unlikely). And finally (knock on wood), my vibration problem will be solved. As a result of the pursuit of this ever elusive gremlin, I wil have a new car!
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
