Old 06-26-2007, 09:30 AM
Sam Bozzette Sam Bozzette is offline
Cobra Make, Engine: A&C , 466 Ford, 5speed Tremec
I have done it that way myself and it always takes a lot longer to get the air to clear and a lot more fluid as you dont want to re-use any you have pumped through the lines. I believe the master cylinder has a lot of areas in the valving that can hold air. I have friends that are pro mechanics and they always bench bleed the master first. Sam
