Thread: Help!!
Old 07-08-2007, 08:52 AM
Gun Doc's Avatar
Gun Doc Gun Doc is offline
Cobra Make, Engine: BDR#499 351W with Webers
Okay, here is the update: I disconnected the throttle cable (it works fine), and connecting linkage from the bell crank to the left two carbs. The forward carbs works fine, the rear, however, is locked up. This is with the left to right linkage disconnected, as well.
My question is now this: Do any of you think this linkage set up my have damaged the carb (linkage shaft), or is it possible that it is just tight? It looks as if the shaft may be rubbing on the forward carb's shaft...
BTW: The right bank carbs work fine.
I am open to anything at this point, as I am still 80 miles from home and can't get past just off of idle.
Thanks,
Gun Doc
