07-11-2007, 09:58 PM
NSW
Thanks to Dan.
Originally Posted by CobraDan
The LS2 is shipped from GM rated at 400 hp at 6,000 rpm and an equal amount of torque at 4,400 rpm. The redline is 6,500 rpm, but it's all done building power by 6,000 rpm. Remember that this is an engine designed for an emission-compliant production car, so the camshaft is pretty conservative, and the heads, while excellent in many regards, are designed to flow enough to support this camshaft. The factory LS2 also runs a 65cc combustion chamber and a stout 10.9:1 compression ratio.
The LS2 is 350 Cubic inches
Thanks for the technical info Dan. That helps me a lot. All I have to do now is work out what colour is my desired finish for the duco.
All the best
Baz
