  #23 (permalink)
Old 07-29-2007, 05:06 PM
priobe's Avatar
priobe priobe is offline
Cobra Make, Engine: E-M Cobra Ford FE 427 w/ Webers 48 IDA
UPDATE:
Ok after cursing for about 2 hours and battling the removal of the toploader tranny, I think I figured out the low oil pressure problem. Apparently my Engine builder installed the pressure relief valve incorrectly in the back of the block.
This is what I found after removing the allen plug that is located above the camshaft was the spring then plunger in the block.
I know it should be spring 1st the plunger with the stem facing toward the allen plug.
Now since I have the oil pump in hand which I verified is a HV pump shoul I replace it with Precision oil pump and high pressure spring?
The oil old pump looks perfect.
I just figured since it is off should replace it.
What are your thoughts?
