Old 09-08-2007, 09:20 PM
fsstnotch fsstnotch is offline
Ya, those heads don't look bad. Looks like they could benefit from a gasket match but otherwise not too bad. The 210cc heds are $795.
Dwight, what cam are you running? Did you upgrade the springs? Anybody have spring recommendations if I were going to run one of thses cams?
http://store.summitracing.com/egnsea...splayPrice%7C0
I will likely use one of the track heat cams, edelbrock air gap dual quad setup, pro comp 210cc heads, 1.6 roller rockers, and reasonable compression 408 stroker roller motor. Something that can stay reasonably reliable to drive alot! My car will not be a garage queen! haha
Bagram AF Afghanistan
