Originally Posted by 67JET
I can't find out how to identify the year and raito.
Markings are:
bolt-tag = 2-88,
10 bolt cover,
C3
S,
A84,
6098. With that I also haven't been able to find out how to align it. Right now my tires set out at the top. Any help would be great, thanks.
JET
hi there you have a 2.88-1 ratio which is the highest ratio jag do on that axle type. if you have a tag with PL on it ,then you have a powerlock diff (limited slip) otherwise it is astandard open diff.adjustment is as already stated , by shimming,you will get the best handling by setting the toe_in as neutrel ie 0,this avoids getting oversteer ,not a good idea with a cobra as they want to oversteer already.
