Old 09-17-2007, 08:01 PM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
Hi me again. The Salisbury diff has disc clutches and the Dana has a cone clutch.There is many differing opinions on the two.I prefer the Salisbury with the discs.There are two rear jag springs. One has 9 coils and the other 7 coils.Infront I used the one with 9 coils and in the rear one of each on each side with 3 way Gabriel adjustable gas shocks.If I remember I set the front shocks in the middle and at the rear one in the middle and one soft each side.
Front and rear toe are set at 1.5 Degree in and 1.5 degree negative camber all around.On the track I have always placed 1st or 2 nd out of a field of 40 cars so I guess that my setup works pretty well. Also in front I used a Granada sway bar (modified to fit) 1" diameter and a 1/2" diameter sway bar in rear.The car drives very smooth and has very little sway.I love it the way it is.
