Old 10-08-2007, 05:35 PM
Three Peaks Three Peaks is offline
I installed the engine block so I can attach some junk heads to start fabbing my headers and my engine seems to be sitting lower than I thought it should. I notice my stock oil pan sticks below the rails by about 1/2" or so.
What is the dimension on your cars from the top of the rails to the engine mount bolts? I may have to redo my motor perches on the frame......
Thanks,
Bob
Enyawix,
I was referring to the Mustang H pipe set up you plan on using under the car. I'm just curious how you plan to fit it all in given the limited space and clearance under these cars.
Bob
