Old 10-13-2007, 04:46 PM
stephen low's Avatar
stephen low stephen low is offline
Thanks for the suggestions guys - good stuff.
What I failed to mention is that the external part of the fuel pick-up / supply tube is actually cracked rather than the whole tube just being loose.
Sadly the crack has occurred close to the tank, so I can't just cut off the offending bit.
Could I still solder repair the tube, do I need to replace or is there another fix possible?
slowy
