Old 10-23-2007, 03:51 PM
Naumoff's Avatar
Naumoff Naumoff is offline
Cobra Make, Engine: Unique 427 S/C 427 FE S.O. 484 cu in
Originally Posted by Chaplin
Thanks Loadco- my t-stat did not come with any fittings from canton. I picke up some standard fittings and they look too long. Maybe I'll call Canton and see if they can send them to me.
Tony- that mocal unit opens at 180, which may not be hot enough. The canton opens at 215 I believe.
Chap,
180 is plenty hot enough.
If you push it the temp will go over 215 with no oil t-stat.
It is the cruising around with no load on the engine and winter that I want to get the oil temp up faster.
