Old 10-26-2007, 12:23 AM
stephen low's Avatar
stephen low stephen low is offline
Ross
Thanks that might be just the tonic. I'll have a chat to a few people on that one.
I do recall asking the brake specialist I was getting bits from, and whom helped reco the master and replace the reservoir after I found it had self destructed, as to whether you could alter the inbuilt proportioning valve.
If I remember rightly the answer wasn't no, but it didn't sound like a necessarily easy fix. Worth a try though.
Now as to Cam2's suggestion, I think his thinking is off this planet or at least he is out of his tree, let alone the square!!
But logically, if I leave the system full of air, I'll get no lock ups at all - correct?
Problem solved - sorta!??!
slowy
