Old 11-02-2007, 05:53 PM
patrickt patrickt is offline
Originally Posted by ng8264723
Did you run a short input shaft? What size flywheel and clutch?
No, I use the spacer that you can see below. I have the SCAT 4.125" stroker crank in my 428 FE so I use the 427-type "zero balance" aluminum flywheel from Centerforce. NOT the externally balanced flywheel that you would normally use with a 428 (because my FE is now internally balanced). That flywheel will handle up to a 12" clutch; I use 11".
