Old 11-03-2007, 02:50 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
mrp e - I battled two different problems with the clutch reservoir. First there was a leak where the hose attaches to the bottom of the reservoir. Then, the reservoir itself was leaking where the clamp holds the top/bottom piece of the reservoir together.
You might want to check to see if you have any other leaks. If your reservoir is empty, it may be the something else (unless the hose has completely deteriorated).
I'm going to replace the hose when I get a chance.
Doug
