Old 11-09-2007, 11:48 AM
Murphy's Avatar
Murphy Murphy is offline
Cobra Make, Engine: Kirkham #473 427 every option, Keithcraft aluminum FE 482 ci. Mass Flo FI. Tremec TKO 600.
Default Spacer puts the trans mount in the wrong place
On a Kirkham the long shaft will push your trans back so the mount will not work and it will cause the trans to hit the crossmember that holds the mount. Order the Tremec with the short shaft. Look up David Kirkhams thread on the modification for the scattershield so it does not hang down below the frame.
