Old 11-16-2007, 08:30 PM
63mercury's Avatar
63mercury 63mercury is offline
Cobra Make, Engine: Scratch building frame,FFR Mkll body ,302w, and T5 trans, 3.0 rear.
The 460 in the Merc has the following specs; bored .060, ported 72 Lincoln heads, 3 angle valve job, line bored and decked.020, flat top hyperutectic pistons,ballanced,comp cams 270h cam kit,standard oil pump (75# cold @ 2000 and 60# hot @ 2000),Edelbrock performer intake, Edelbrock 750 carb,2"primary tube 3.5" collector hedders, 2.5" exhaust into flow masters,it has approx 9.75 to 1 compression and runs great on 93 octane pump gas, oh the ignition is stock Ford with a Mallory box. The Dyno 2000 program shows 475-490hp and 525-550 ft lbs torque. I hope this helps.. Carl
1963 Mercury Monterey 460+ .060 .//Cobra clone, Scratch build frame /302/ T-5 WC / 3.00-9in/FFR mkll body (Broken but repairable) /91 Lincoln Wire Wheels // : N.S.M.C Charter/Life Member// Die Hard Blue Oval Nut
The finish is better than the beginning. Ecc7:8
