Old 01-31-2008, 09:01 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
Smile Fantastic IFS For Butler Cobra
Hi Fellow Butler owners,
I've been searching for an upgrade suspension that would replace the old & tired MGB setup for a number of years. Well I found it and it's installed.
I had to make a minor modifications to the chassis, Elongate four holes in the new crossmember that took 30 minutes, remove a corner of the fibreglass inner cowl and a new aluminum 27" long steering shaft makes the connection from the new rack to the steering column. I'm so looking forward to driving the car when the weather in Chicago improves.
I believe that this is the best suspension upgrade you can find and the weight is about 80 lbs. lighter.
I've included a link to the site. If you call Ted, Mention my name, He has been most helpful in the process and is a thorough gentleman.
FAST CARS, Inc HOME PAGE
Arthur Mitchell
