Old 02-10-2008, 06:20 AM
Goopie 18 Goopie 18 is offline
Cobra Make, Engine: SPF 2473, Roush 427R
I also replaced my flat mirror with a convex mirror using the original housing. Using Performance unlimited's convex stick on mirror, you remove the black plastic backing with a razor blade or exacto knife (be careful not to scratch the reflective backing). Remove the original chrome housing from your mirror by undoing chrome screw in back of mirror. You then remove the original glass from its plastic bezel. Your convex mirror is then placed into the original plastic bezel. Notice that the spring tension inside the mirror will need to be increased. Reassemble and you're all set. Easy to do. Takes about 1/2 hr. Looks perfect. Much better than stick on. Works great!
