SUPPORT OUR SPONSOR
  #21 (permalink)
Old 02-09-2008, 01:34 PM
Cobra Make, Engine: Superformance, Roush 402R, Kentucky Cobra Club
I bought a metal-backed stick-on model at the local parts house. Probably the 3.5 inch model. The secret is not to stick it on. Remove the stock item and replace it with the new one using the same technique as the original used to mount the mirror in the mirror body. Your net position is a convex mirror in the original mount that looks perfect and works well. No, you cannot see through the rear fender, but your blind spot is gone.
  #22 (permalink)
Old 02-09-2008, 03:13 PM
Cobra Make, Engine: Superformance Brock Coupe
Default Cobra mirrors
Mirrors have always been a problem on Cobras. If you'll go to BRE2.net you'll see the proper solution. Badger
  #23 (permalink)
Old 02-09-2008, 03:59 PM
Neat site - that TR7 looks so cool - if only they would have built it!
  #24 (permalink)
Cobra Make, Engine: FFR, 331 Sportsman block, T5Z, 3.55 IRS, Fuel Safe cell
If you decide to replace the mirror, look at one of these. I use the 4" model, and it works great.
peep mirror
FFR, 331 SBF dynoed 372RWHP@ 6100 RPM on 87 octane pump gas
  #25 (permalink)
Old 02-09-2008, 04:32 PM
ou812545's Avatar
Cobra Make, Engine: SPF 2168, 418, TKO 600
Chilibit,
I your idea of replacing the existing mirror with the convex one in the same housing.
Do you have any pictures of yours?
Thanks,
Dan
  #26 (permalink)
Old 02-10-2008, 06:20 AM
Cobra Make, Engine: SPF 2473, Roush 427R
I also replaced my flat mirror with a convex mirror using the original housing. Using Performance unlimited's convex stick on mirror, you remove the black plastic backing with a razor blade or exacto knife (be careful not to scratch the reflective backing). Remove the original chrome housing from your mirror by undoing chrome screw in back of mirror. You then remove the original glass from its plastic bezel. Your convex mirror is then placed into the original plastic bezel. Notice that the spring tension inside the mirror will need to be increased. Reassemble and you're all set. Easy to do. Takes about 1/2 hr. Looks perfect. Much better than stick on. Works great!
HTML code is On
