Thread: build party?
Old 02-13-2008, 03:16 PM
cheap's Avatar
cheap cheap is offline
Cobra Make, Engine: FFR Spyder GT, 347
I have compression x8, gas, and spark. The relays work as advertised (EEC turns on, FP turns on and runs). It'll start sometimes, it won't others. When it will start, it won't stay running. It will either A) die after a few seconds, or B) die the instant I touch the throttle. The IAB solenoid works. It's a mass-flo system calibrated for #42s, which I have installed. Timing is set about 10* BTDC and FP is between 30 and 40 w/ vacuum disconnected. All parameters are set so the car should at least RUN, even if it is poorly.
