Old 02-16-2008, 07:51 AM
Ant Ant is offline
Default Bandsaw Blade TPI
Originally Posted by macloft View Post
Engineering class theory says 2 1/2 to 3 teeth for the thickness of the material being cut.
Bruce
macloft, does that mean amount of teeth touching per inch for material length of cut? as for eg I cut a Jaguar HT suspension bolt and on a 14tpi sawblade, about a 2" length of teeth disappeared which probably was a bit hard for the blade and to small a diameter for the tpi?
Thanks guys for the advice and going reasonably fine with the teeth maybe better than coarse and keep it at 18-24tpi.
A J. Newton
The 1960's rocked!
