Old 02-20-2008, 11:09 PM
n6opv's Avatar
n6opv n6opv is offline
Arthur,
Got it. I thought you had somehow come up with a way to eliminate the intermediate shaft altogether and only have the one u-joint That sounds like it should be a much nicer setup. Thanks for the clarification.
Jason
Originally Posted by lal Naja View Post
My new intermediate shaft is 27" long and connects directly from the steering column to the Fast Cars rack. The angle of this connection is now different and the angle of the 27" shaft is lower than the original setup. (The MGB rack shaft is at a higher angle) The Fast Cars rack is also a few inches maybe 3 inches lower than the MGB rack and the pinion is a litter closer to the center of the car, say 1". So to make a direct connection from the steering column and the rack I choose to cut the cowl and eliminate another U-Joint. I will remold this cutout section with new fiberglass.
Hope my explanation is clear.
