Old 02-24-2008, 11:03 PM
SantaFe66 SantaFe66 is offline
Cobra Make, Engine: Cardiac, 428 FE
I had the same problem with Wilwood reservoirs. I called the tech line and they suggested replacing the o'ring and heating up the top before putting it on. He also suggested that I not tighten the wire clamp too tight and make sure the wires straddle the o'ring. Seems it deforms the joint when you over tighten it and then it leaks. Just a gentle tighten and it hasn't leaked since.
Good luck.
