Old 03-02-2008, 09:02 PM
greg schroeder's Avatar
greg schroeder greg schroeder is offline
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
Originally Posted by mpanten View Post
Those are some impressive times Greg. I know you are running a roush 427 but can you tell me more about your setup. Gearing, Hp, tires etc...?
The Roush 427R is the basic deal with single plane intake. I got rid of much of the goofy stuff that robs power and some other stuff that might break, so now the motor can put out close to what it should at the wheels with reasonable reliability. It's about 475 HP at the wheels now. The performance and reliablity things I changed to from how the car was delivered are:
1000 cfm Pro-Systems carburetor
S&B taller oval air cleaner
8AN (1/2) fuel line from tank pick up to carb
Aeromotive 100 micron fuel filter
Upgraded half shafts from The Drive Shaft Shop
Detroit Tru-track rear installed inside the Ford 8.8
2 inch primary headers
Buckshot Racefab stainless side pipes
McLeod light weight flywheel
SPEC stage 3 clutch
SWI engine mounts
I have a set of 275/60 15 Mickey Thompson ET street drag radials. I drive around town with about 21 psi and also the same at the strip I've found works well for the casual starts. Just start from idle and nail it. That's about it. It has the stock Superformance IRS design and the basic TKO 600 with a 3.73 rear gear. The tires are 28" tall.
off idle drag pass, DA 750ft.
