Old 03-15-2008, 02:00 PM
Texas-Saluki's Avatar
Texas-Saluki Texas-Saluki is offline
Cobra Make, Engine: JBL - TK0600, Electromotive EFI, Keith Craft 408W "standard crate", ~575hp
Send a message via MSN to Texas-Saluki Send a message via Skype™ to Texas-Saluki
Originally Posted by CHANMADD View Post
If it has always been only 25 psi it could be a restriction somewhere that has now caused a crack or a leak of oil into the coolant.There is really nowhere in the engine that the oil should mix in the coolant even with a blown gasket.A head gasket would put coolant in the oil, not oil in the coolant. Very curious!!!??
well I am going to do a compression check this afternoon... but it seems like it is the intake maybe the problem... hope I don't have a larger issue.
I may also try and find a oil pressure tester to determine if my gauge or sender are bad... I have always thought it was low... but this motor does not even have 3k miles on it
back to the shop I go
Chris Noland
JBL
Flower Mound, Texas
http://www.thenolands.com
www.txcobraclub.com
