Old 03-19-2008, 08:17 PM
SoTxButler's Avatar
SoTxButler SoTxButler is offline
Cobra Make, Engine: Butler...488" hi-rise, dry-sump FE s/o w/stacks
Hi Anthony,
Thanks for the info. Is your manifold available? It would take some machine work, but I think I could resize to 48 and even cant the mounts 10 degrees. It is a nice looking manifold. You may be right about the size of all the manifolds of that day and you are right about the throttle bodies I plan to use. I will be using 50's from VeryCoolParts.com
Russ
