Old 03-20-2008, 05:09 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Sorry, my manifold is not available.
However, I do know of another FI system like mine, although I don;tthink the owner is selling, as he wanted to bujy mine as well.
A couple of years ago, there was a hi-riser engine / cobra for sale with this exact set-up but converted to EFI, and I'm thinking the induction system or engine may have been separated from the car. If you can find a set up like mine, then you can use the throttle bodies as supplied, converting them to EFI.
Also, Algon made mechanical FI systems for Hi-riser heads as well, the only one I have seen had the throttle bodies (whiche were cast into the intake itself) oriented straight up.
Good luck.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
