Old 03-20-2008, 05:31 AM
Double Venom's Avatar
Double Venom Double Venom is offline
Wetdog,
Adding to the top of the dash will basically do nothing but cause a huge interference problm, not only with the mounting of the dash but will force all the gauges, hardware wiring, etc, downward. With two 90' mounts mounted at the bottom (custom dash), and the top of the dash installed correctly it should be more than stong enough to install a swich for the halon system.( you are running lines from your installed system to the drivers foot box and the engine compartment-no?)
Just my 2-cents again.
DV
