Old 03-26-2008, 10:01 PM
Curt C.'s Avatar
Curt C. Curt C. is offline
Cobra Make, Engine: Classic Roadster; 351W
What are your spring rates in the front and rear? Put the front bar back on. In front, I have QA1 coilovers 500lb, Behtania A arms, the CR front bar. In back its 9 inch ford, Bilstein coilovers (250 lb) along with a 1979 4 cylinder sway. I had the larger CR rear sway bar and it was way too much - severe oversteer. Car does well on the road course and keeps up with modern day marques. However, the four link Ford has inherent issues with bind. It would be nice to have a 3 link or torque arm / watts link but this would have to be customized. I know of no CR's with this setup. Before you start spending money, put the front bar back on and see if that helps.
