Thread: PCV use
Old 04-06-2008, 08:40 AM
bigrob's Avatar
bigrob bigrob is offline
Cobra Make, Engine: BDR # 126/ K. Craft 306 CID/375 HP- 306 RWHP
Originally Posted by Woodz428 View Post
I'm a strong believer in PCV's, I wouldn't remove it. Some issues that can arise are TOO much crankcase pressures that will create oil leaks in certain areas, as well as blowby from the same build up of pressure. Unless you plan on an evac system plumbed into your exhaust, leave it alone. If you are planning on an evac system, don't, unless it is just for the track.
I did think about the pressure side of it, but wondered, if that is one of the functions, why is it not plumbed to both valve covers? I believe my Corvette IS plumbed to both for THAT reason.
Rob
" Listen to that music! "
'65 BDR #126
'84 Porsche 928S
'01 Corvette C5 coupe
'99 Ford Explorer Limited
