Thread: Rear hub broken
Old 04-27-2008, 11:38 PM
nanard289 nanard289 is offline
Cobra Make, Engine: Cobra Daytona (from USR) 302RDI Yates headed + Weber induction
Originally Posted by Jac Mac View Post
Nanard289, It might be time to try something else like the rear wheel brg assy from a 84>> corvette. The stud spacing is very close if not the same as a Jag, has a fine spline axle etc & the hub assy bolts on to the upright with three bolts. If your still using U-joints you might even find that they are the same series as the jag, earlier vettes use UJ- later are CV. plenty of these advertised on ebay-just type in 85 corvette rear axle brg in your seach question ---should get you there. We have them in the TVR out here-- no hassles with them to date.
Hello Jac Mac
Coincidence! Your comment is exactely what I was looking for. As you say, a Corvette rear end adaptation including half shaftes and bearings could be a good solution. I have to found a Corvette hub to check the bearing size and to to see if an adaptation is possible
