Thread: Manifold search
Old 04-28-2008, 06:54 AM
BOURRET's Avatar
BOURRET BOURRET is offline
Club Cobra Member
Cobra Make, Engine: Paint:Metalflakes Royal and Abalone stripes registered in France in 1973. Engine: Ford Shelby aluminium block, 482; two 4-barrels 600cfm Holley; Edelbrock Performer Aluminium heads,,fluid damper,4-speeds Aluminium Toploader (short), 2.88rear
Send a message via Skype™ to BOURRET
Originally Posted by undy View Post
You need a medium riser to match your eboks. I don't believe that manifold will work for you. It's a 427 sourced low riser. You'll have to epoxy the bottom of the ports the get any kind of match. Your performance will sufffer too, especially with that 482. The medium risers came about in 65, if I remember correctly. Get one for the dual quad "WOW" factor but at the expense of quite a few ponies.
Dave
Thanks for the remarks.
The height between the bottom of the manifold and its maximum height is very critical, I think I have about 1/4 inch clearance available!!!
My actual (porous C3EA 9425) had been carefully re-worked three years ago to match the Edelbrock performer cyl. heads.
What would you see to save the "ponies" ? Switch to a big single quad carb???
Queenie
