04-28-2008, 09:23 AM
Club Cobra Member
Fra
Cobra Make, Engine: Paint:Metalflakes Royal and Abalone stripes registered in France in 1973. Engine: Ford Shelby aluminium block, 482; two 4-barrels 600cfm Holley; Edelbrock Performer Aluminium heads,,fluid damper,4-speeds Aluminium Toploader (short), 2.88rear
Originally Posted by undy
Depending what manifold height you have available you might not have enough room for even a good flowing single carb two plane, much less a single plane. I'm running a Blue Thunder 427 MR on my KC Pond 482. Keith said that it would flow well for my application (Stage II CNC'd eboks, 11 to 1 and 240/250 @ 640 hydraulic roller) It's actually about 1/4" taller than the Performer RPM. I'd like to switch to a Super Victor but like you am space limited for that height. What's your max clearance measurements, manifold base to carb pad height (front and rear) Blue Thunder does make a medium riser dual quad set up, not knowing if it'll meet your clearance requirements. I like the Blue Thunder manifolds as the are fairly accurate clones of the OEM stuff, with flow enhancements too.
Depending on your setup, probably +/- 20 hp drop... maybe more, on running a low riser.
Dave
I will go to my garage this evening (it is a few miles from my home) and I will make the measurements. I never looked at Blue Thunder until now but I am interested by your set up which seems excellent. A Blue Thunder dual quad could be the solution.
Thanks again!!!!.
Queenie
