Thread: Boss 331
Old 06-10-2008, 01:27 PM
DAVID GAGNARD's Avatar
Originally Posted by vector1 View Post
i don't think the issue is with crankshaft clearance, it is the piston dropping out the bottom of the cylinder distance.
I've looked at mine from the bottom up when assembling the short block and while it does look like the bottom of the pistons stick out the bottom of the cylinders a lot, it is actually very little difference from a factory block......
No way the piston can "drop out" the bottom of the block while still connected to the rods and crank.......
David
DAVID GAGNARD
