  #32 (permalink)
Old 07-04-2008, 05:05 AM
Andrew429's Avatar
Andrew429 Andrew429 is offline
Cobra Make, Engine: G-Force MkII, Ford 429, Tremec TKO, Jag Suspension, Sequential LPG Injection, On The Road.
Hi Baz,
Have you had a win yet with getting the tap out ?
To add to the suggestions, a stud welder might be an approach worth considering.
Heavy machining/engineering firms, especially mining oriented ones use these.
It will allow you to reach into the back of the tap and should form a weld with a good surface area providing enough strength to back it out.
Andrew
