Old 07-05-2008, 06:23 AM
flipscobra flipscobra is offline
Cobra Make, Engine: Superformance aluminum427
I have a spf 427 what I did was javk the motor up after I cut motor supports loose shift motor as far as you can, then put a brick or whatever you can get under the motor support on the head your going to take off then let the motor down this will twist the motor up enought for you to get to the bottom studs worked for me, good luck
