Thread: ignition grief
  #29 (permalink)
Old 07-13-2008, 09:21 PM
lovehamr's Avatar
lovehamr lovehamr is offline
Stolen Avitar
Originally Posted by Cobrabill View Post
Your comment about using the MSD box with points doesn't effect timing is,100% catagorically FALSE.
Um, when did I say that? I said that "dwell" wasn't affected. You do know that there is a difference, right? Does that make the above statement 100% catagorically goofy? Or were you referring to my saying that it would take a long time for rubbing block wear to make an appreciable difference in timing? In which case the above statement would merely be lacking in accuracy and understanding. Man, this is like watching a liberal foist words into other people's mouths. I didn't say that I didn't have any point bounce, what I said was that I had no problems. And I believe that this may illustrate what everyone’s problem seems to be with this line of thought; you see, my point is NOT that points are a more precise or better way to trigger the MSD box. My point is that points are a reliable and still viable way in which to do this because most of us would never feel the difference anyway. Of course I know that your sensitive booty would pick up on those points in your distributor right away as you put on that second coat of wax!
By the by old boy; the next time you feel like showing of that big brain you may want to use spell check.
Steve
