Old 07-18-2008, 02:39 AM
PANAVIA's Avatar
PANAVIA PANAVIA is offline
OMG...
reproduction alternator brackets STARTING at 450!$
Holy CREPOLA.
From the EBAY Site
"This is a newly reprduced 289 Coba alternator mounting bracket and adjusting arm assembly. These were used when the cobras were changed from the generator charging system to the alternator charging system in 1964. These have not been available since the '60s and were unique to the cobras only. If you are converting your early 260 or 289 cobra to a alternator charging system this would complete the factory conversion look. the mounting bracket is made from a steel casting (for strength) versus the originals iron which is undetectable. The casting also carries the original foundry marks. the adjusting arm is made as the original. This assembly can also be used on many of the kit manufacturers also, Kirkham, ERA, etc...for that original look. The photo is of an installed assembly, you will be gettting new parts. "
450>????
--Steve
