Old 08-22-2008, 05:35 PM
FUNFER2's Avatar
FUNFER2 FUNFER2 is offline
What about the heat produced ? I know the turbos can be heat monsters.
With the blow in charger, is their enough room under the hood or did you have to make the scoop taller ? I don't think the 385 series like you have is any bigger than the 427 or 428 ?
I do have the higher Vic Jr. air gap intake than the RPM manifold.
On Shelbys supersnake, the scoop and hood is taller.
What computer will you use ?
And, do you have a projected cost ?
Regards,
Kevin
