Old 11-01-2008, 10:05 PM
Got the Bug's Avatar
Got the Bug Got the Bug is offline
Originally Posted by cobras View Post
all looks good and tight everywhere else, i can see the u joint when i wiggle the steering wheel and the play is in the u joint. the bottom half of the joint does not move but the upper half does theres play in it.
shouldnt this be covered under warrenty tho?, car only has 700 miles on it
Did you buy the car new or used? If used, the warranty doesn't transfer to a second owner. That being said, it's a safety issue so your local SPF dealer should jump in and help you resolve the problem.
Doug
