Thread: panard bar
Old 11-09-2008, 11:31 AM
SuperHart's Avatar
SuperHart SuperHart is offline
Cobra Make, Engine: Cobra Fibercraft Bodies 427 S/C, 351W disguised as a 427.
Send a message via AIM to SuperHart
I'm not sure if the photos of my installation will help much but they are the only ones I have. I installed the bar in a lower position to make adjustment easier. Since my car sees no track time the only purpose of the panhard bar is to prevent lateral movement of the rear end assembly. The inside bracket was fabricated from 0.25 steel plate and attached to two lower bolts on the pinion bearing retainer on the carrier. I used Grade 8 bolts 0.25 longer than stock and cross drilled the heads for safety wire. The outside bracket was welded to the chassis in a convenient location.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
