Thread: gen 3 t/bodys
Old 11-19-2008, 05:17 AM
Plums Plums is offline
Even if you buy the pro version and get a Wideband O2 to go with it, it would be under $1500 (this would be the best set-up by far).... You will then be able to do everything you need to after I send you the initial program. The best thing is, that if you have the software, I can just e-mail you the tune changes after you send me the scan logs to work with.... It would most likely take a fair amount of time and lots of e-mailing over a few weeks, but it would be worth it in the end!!!
The software uses the OBDII port, (the diagnostic port under the dash in Holden vehicles) straight to the PCM.
