Old 11-21-2008, 02:54 AM
Ozgur_Tan's Avatar
Ozgur_Tan Ozgur_Tan is offline
Cobra Make, Engine: scratch built 289 eclectic mix of fia/ussrc/early comp
as you can see on the updated pictures of my buck
i make sections as -18 mm offset from outside surface
than cover with 18 mm plywood strips
to archive good surface quality
ps:
i would like to double check outside diameter of front headlight bezel, can you assist me ?
regards
ozgur
Originally Posted by jberg View Post
Looks like you are doing a similar project like I do (if I understood right).
I made first wooden/foam (polyurethane) buck and finally pull a mold out of that (not completly ready yet).
I spent a lot of time trying to make that plug surface perfect and that is a nightmare if you have wood/foam plug like I have.
My main problem was that no matter how nice surface you make that wood sections will be visble after few days. Wood and foam just act differently in different temperature/moisture etc.
If I started now all over again I would add few layer of glass mat after rough finish of foam. That could made that plug more solid so that there is allways same material under filler.
If you like to know more about my project send me a mail.
There is also some pictures about my plug/mold in my callery.
