Old 11-22-2008, 08:47 AM
fkemmerer's Avatar
fkemmerer fkemmerer is offline
Cobra Make, Engine: ERA, FE BBF
Originally Posted by philminotti View Post
What AN size hose should I run between the remote oil filter adapter block and the filter? Motor is FE 482 with HV oil pump.
Thanks, guys.
phil
Phil,
Suggest you use -10AN. Choose good quality hoses and fittings (I like Aeroquip) and make sure you blow out and completely clean the lines before installing them as any dirt or fillings in oil lines can damage your engine.
- Fred
