Old 12-05-2008, 11:23 AM
xracerbob's Avatar
xracerbob xracerbob is offline
Cobra Make, Engine: ERA 758 KC Pond 482
The motor is certainly an FE series (390/428/427) and with screw in freeze plugs it is more likely a 427. Look for 3 bolts in the side of the block just above the oil pan to see if it has cross bolted main bearing caps. This would also indicate a 427.
