Thread: 540 Update
Old 12-21-2008, 11:29 PM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Warren you say you had to reposition your o2 sensors did you just cut out the fitting and shift it around the side and patch the hole up in the top?
Cheers Mark
