Old 12-29-2008, 07:26 PM
vector1 vector1 is offline
Cobra Make, Engine: jbl
Originally Posted by wrench87 View Post
john wha t did you use for a throw out bearing?, i noticed that the internal throw out bearings for the race clutches uses a rounded edge bearing and a chevy bearing is flat?.
you want to use a rounded face if you are using a small dia. press. plate because the fingers will roll across the bearing when depressed, a flat bearing is good to go on a larger dia. press. plate where the fingers will not roll onto the outside edge or the bearing movement is smaller, or something like that.
