  #22 (permalink)
Old 01-01-2009, 09:34 AM
Pete Munroe Pete Munroe is offline
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Default which series McLeod t/o do you have?
Rosco,
WHICH t/o do you have...the early or late one? And WHERE is the leak? At the HOSE FITTINGS or the RAM?
The McLeod t/o early units leak at the hose fittings. The "banjos" were poorly made with excessive clearance. That was completely redone, new fittings and housing.
The NEW series, made in last ~5 years has been fine for me. No banjo fittings. They have replaced the banjo's with machined 90 degree hose fittings.
Go back about 5 threads or so to one on 11/16/08 titled "Trouble shifting a TKO 600" or something like that.
Trouble shifting a TKO 600 while engine This thread covers the topic pretty well, the late model McLeod unit
picture of the late version:This is a picture of the latest series unit with the new housing and hose fittings.
http://www.mcleodind.com/downloads/p...Fs/Page_10.pdf
Originally Posted by Rosco View Post
Well, finally determined my McCleod Throw-Out Bearing is junk (leaks).
I am trying to replace with a Tilton Bearing however the measurement is not quite right in terms of mating to the Clutch Fingers. I currently have a McCleod Clutch set-up...
Anyone ever try doing this? Using Shims? Any help or direction is greatly appreciated.... Pictures if possible..
Trying to avoid going the slave cylinder route...
Thanks,
ERA 289 #2027
