Old 10-31-2001, 08:00 AM
Satanpez Satanpez is offline
I don't think the aftermarket setups remove the mass air, as it's essential if you're using a mass air computer etc.
Easiest way is most likely the ford setup. Altho expensive.
Cheapest way would most likely to be purchasing an 89-93 harness/computer etc and cutting it down. It's what most FFR people do.
You can purchase everything needed usually from someone who is going carb instead of FI but using a donor.
Also it may depend on what you have already as far as mass air sensor, and a computer.
I believe holley has a conversion kit out now that includes everything but the computer.
Harnesses usually pop up on Ebay from time to time too.
I would suggest not using a 94/95 harness as the computer for those years had less aggressive timing. (plus, but not sure, they may have had coil on wire ignition)
Look on cobraforum, there's some info on it.
-steve in nj-
